Video, picture and text guides, in various languages, about how to use Cubik Studio.
Post
by akkechi » 11 Dec 2016, 11:04
Part1 Beginner
Part2 Little polygon
Part3 tubes
※It is not perfect, but if you do not have a preference, this is enough.
4 x
akkechi on 11 Dec 2016, 14:04, edited 3 times in total.
akkechi
3 x | 11 x
Post
by Sphax » 11 Dec 2016, 12:35
A way which would produce less polygons is by using same technique but positioning origin on the middle of each element (instead of border).
Also, before rotating elements, be sure to remove hidden faces to create less polygons.
- Admin
70 x | 223 x
Post
by akkechi » 11 Dec 2016, 12:50
Sphax wrote: 11 Dec 2016, 12:35
I also do a method to decide the rotation axis, but I chose an easy method.
2 x
akkechi
3 x | 11 x
Post
by Sphax » 11 Dec 2016, 13:17
That's cool to see such video in a short format. The 1st method is nice to create tubes and second to create cylinders.
The 2 videos you made are showing how easy it is now to rotate elements thank to v2.4.
- Admin
70 x | 223 x
Post
by Geenium » 11 Dec 2016, 13:40
You can increase the accuracy of the shape by using 5.028 instead of 5 for the length of elements, this way the elements will line up much better with each other.
Geenium
74 x | 15 x
Post
by akkechi » 11 Dec 2016, 13:58
Sphax wrote: 11 Dec 2016, 13:17
I made a video in Part 3.
2 x
akkechi
3 x | 11 x
Post
by CaptainGalax » 11 Dec 2016, 14:07
btw, a Hexagon & hexadecagon is planed for my Addon!:)
CaptainGalax
13 x | 18 x
Post
by Sphax » 11 Dec 2016, 16:24
CaptainG4laxy wrote: 11 Dec 2016, 14:07
Your addon is using meshes. The videos @akkechi made are useful if users want to keep the clean/smooth/lowpoly aspect which can't be get after a voxelization.
@akkechi your 3rd video is private
2 x
- Admin
70 x | 223 x
Post
by akkechi » 12 Dec 2016, 02:14
Oh, Sorry ... I released it now.
2 x
akkechi
3 x | 11 x
Return to “Tutorials”
