Textures default path ??? [Solved]
Does any one know what folder I should be using for textures default path in preferences under tools
- Shelly_Marsh
- Likes: 3 x
- AGearBeast
- Likes: 5 x | 1 x
Re: Textures default path ??? [Solved]
Path in preferences are just there to help you speed up work by putting the browsers directly in a path depending on what you are actually searching.
So for textures, just point it to where you are storing textures (or where it is shorter to find textures)
