When I install Cubik Studio where does the folder tha contains tha app store? (WIN10)  [Solved]
Post by WRLD_OFF » 18 Aug 2021, 17:23
I bought and download cubik studio, then by using the cubik updater I tried to download it but when the installation finished there were no quick acceses in my desktop so when I close the app I cant open it again. What can I do to fix this issue? I think that knowing were the app stores it self could fix the issue.
WRLD_OFF
Re: When I install Cubik Studio where does the folder tha contains tha app store? (WIN10)
Post by HanFox » 18 Aug 2021, 17:52
The app stores itself in the same folder you run the Updater from.
Post by WRLD_OFF » 18 Aug 2021, 20:11
In my case it is not like that it is not in that file
WRLD_OFF
Re: When I install Cubik Studio where does the folder tha contains tha app store? (WIN10)  [Solved]
Post by HanFox » 18 Aug 2021, 21:43
Make sure whichever folder you are using you have proper permissions. It may not be able to place the files there, and for some reason they're ending up somewhere else temporarily.
Post by WRLD_OFF » 19 Aug 2021, 10:02
I changed the folder in which the updater was and it worked perfectly. Thank you!!
WRLD_OFF
