Cubik Studio Install Fail  [Solved]
Post by dgarmsd63 » 26 Mar 2017, 21:11
Hello
I just bought Cubik Studio today and I keep getting an install failure.
The failure message says:
Installation failed on file (CubikStudio.exe):
Access to the path "C:\Program Files\Cubik Studio\CubikStudio.exe.tmp" is denied.
To answer your first question, Yes I made sure all firewalls were turned off on my PC.
My system is:
Windows 10 64bit
Intel i5 processor
1 TB hard drive
16 GB ram
Please advise as I am very eager to start using my new software.
Sincerely,
Derrell Garms
dgarmsd63
Re: Cubik Studio Install Fail  [Solved]
Post by HanFox » 26 Mar 2017, 23:37
As it says it doesn't have permission to to access the file (probably when it's moving it from the temp d/l location to where you run CubikUpdater from).
This is usually caused by Windows' primitive file system protection.
Try moving Cubik Studio to another folder, such as on your Desktop, Documents or Downloads folder.
Post by dgarmsd63 » 27 Mar 2017, 23:07
Thanks Hanfox
I will give that a try and see if that fixes the issue.
D. Garms
dgarmsd63
Post by dgarmsd63 » 27 Mar 2017, 23:13
That did the trick HanFox. I just created a folder on my desktop and it finished the install and is up & running.
Thank you again!
D.Garms
dgarmsd63
