Hello!
I have .obj and .mtl object created in Blender.
I want to use cubik to adjust the position of this item in the game, but when I export it, it becomes huge and does not detect any texture.
I need only obj model. No json or java.
Thanks!
obj export becomes huge
Re: obj export becomes huge
Same. On import every OBJ is the same huge regardles the scale inside 3ds Max.
Nevermind, just found out you need to work within a 16x16x16 centimeters (!) cube.
