Neater Textures? (.png layout)
Post by SamThySoul » 21 Dec 2018, 03:58
I know how to export my textures as a .png and have made a successful custom minecraft block, however is there a way to lay out the textures in the .png a bit neater, they all seem to be all over the place and the sides are everywhere, I would like to have them in such a way that I can have sides that touch together if that is possible.
Thanks in advance for any help😊
SamThySoul
Re: Neater Textures? (.png layout)
Post by Sphax » 31 Jan 2019, 11:31
it all depends on how you created the texture. If you let Cubik create it for you after a voxel conversion to elements, then you don't have any control on it. If you want to have a texture well organized, you'll have to do the UV mapping manually
