Changelog: version 2.8
Post by Sphax » 26 Jun 2017, 09:53
Version 2.8 arrives sooner than expected but it brings very cool new things and bug fixes!
You'll be pleased to use a new exporter - Minecraft Model Resourcepack" which will ease modelers workflow - , two new importers "MCPE Entity"and "Minecraft Structure NBT", ton of new features for Mesh edit-mode, a new tool for Voxel edit-mode and plenty of miscellaneous tweaks to ease the work with Cubik. :punk:
Note: For "MCPE Entity" importer, you'll have to rename ".json" to ".mcpe" to be able to import it however (copy and paste the file somewhere before renaming).
:D New features and improvements:
  • :element: :mesh: Replaced "Element" menu by "Objects" menu containing common functions working on both elements, meshes or primitives
  • :element: Elements name only turn red if Model property has "block" or "item" selected in Minecraft tab
  • :mesh: Revamped the Mesh edit-mode "..." menu
  • :mesh: Implemented many new functions for meshes similar to the ones for elements (such as rename, hide, show, lock, unlock, clone, resize, scale, set position, move, rotate, ...)
  • :mesh: New functions to load/save/copy/paste mesh texture
  • :mesh: Moved button to add custom mesh from menu to tools so importing a custom mesh in Mesh edit-mode is way faster than before
  • :mesh: Voxelization is done on selected meshes only (if nothing selected, all meshes are voxelized as before)
  • :mesh: New path parameter in Preferences to select where meshes are located so "Add custom mesh" will directly point to that folder
  • :voxel: Improved Minecraft voxels palette (used by importers)
  • :paint: Added new Paint tool "Noise" which fill clicked zone with random shades of color
  • :preview: Added default camera position for display settings
  • :preview: Changed default skin to more neutral one
  • :preview: Show floor on 3rd person view in Preview edit-mode
  • :import: :voxel: New Minecraft Structures NBT importer to voxels
  • :import: :element: New MCPE Entity importer (Usable with mobs and skins)
  • :import: :cubik: New LNK importer to follow Windows shortcuts (for Windows in Cubik browser only)
  • :export: :element: New Minecraft ResourcePack Exporter (ZIP) containing only the current model replacing glass and white_stained_glass
  • :export: :mesh: Added a message while exporting to OBJ
  • :export: :mesh: Added an error message when exporting to OBJ if model don't have any element, voxel or mesh
  • :cubik: Prompt user to save in case of modifications when menu Open/Merge/Recent file is selected
  • :cubik: Added new icon in Cubik browser for .schematic and .nbt
  • :cubik: Added new icon in Cubik browser for .cubik files
  • :cubik: Bigger default Cubik browser dialog
  • :cubik: New Cubik browser icons (Icons8)
  • :cubik: Less restrictive filter in Cubik browser
  • :cubik: Remember last values used for "Move" and "Scale" dialogs
  • :cubik: Saves window position on close (Windows only)
  • :cubik: Modified message displayed after first registration
:3 Bugs:
  • Fixed bug when converting voxels to elements if an atlas texture with same name already exists (appends a number to the texture atlas name in this case)
  • Fixed Ctrl+S shortcut which will always be triggered even when cursor is in Input field
  • Fixed bug with "All types" in Cubik Browser
  • Fixed bug when importing some JSON models
  • Fixed bug: Elements turn red only if non rotated element is out of world bounds (same as Minecraft)
  • Fixed bug with Voxel extrude tool which did not work when voxel model has a odd size
  • Fixed bug with dark text in AboutBox when Light app skin selected
Bonus reminder: Already released in previous version (2.7), you can get the official Cubik wallpaper below. ;)
For support, use forum (not DM or PM or email) and create your own topic :3d:
Re: Changelog: version 2.8 (WIP)
Post by MyoHtet » 27 Jun 2017, 00:16
On dark mode, selected element(s) cannot be found. Cuz it's same with unelected color. Also some features are like this is dark mode. Please fix that.
MyoHtet
Post by MyoHtet » 28 Jun 2017, 00:11
And also add multiple bones support for mcpe.
And make a menu or list that shows mcpe entities, and able to import from it. Not from external.
MyoHtet
Post by Sphax » 28 Jun 2017, 10:11
@myohtet please submit suggestions in appropriate forum, not in a version changelog
Post by benyg2000 » 01 Jul 2017, 16:40
OMG the new Flood zone option will be my new favorite tool to use to make my models more detailed, THX so much for adding it.
benyg2000
Post by Zeta » 04 Jul 2017, 12:59
Please, make 1.8.9 Export, I'm begging you Sphax
Zeta
Post by Porama6400 » 03 Aug 2017, 03:56
Could you add option to export texture in the texture folder?
And animation?
By the way... What is "EARLY ADOPTER"?
Porama6400
Post by MysteryWorld » 29 Oct 2017, 18:11
after this update i can't open cubik studio anymore, please fix as fast as possible becuase me and my team have a lot of work to do, thanks.
MysteryWorld
Post by UnderLegends_ » 01 Nov 2017, 17:24
MysteryWorld Same
UnderLegends_
Post by Sphax » 10 Nov 2017, 09:02
MysteryWorld wrote: 29 Oct 2017, 18:11 after this update i can't open cubik studio anymore, please fix as fast as possible becuase me and my team have a lot of work to do, thanks.
Press Alt key when opening Cubik so the window position is not loaded.
